跳转到主内容
为什么 "raid.timeout" 选项无法避免环境关闭?
29
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
适用场景
ONTAP 9
问题解答
  • 错误146654- 对于触发关闭的NV电池事件、ONTAP 会忽略"raid.timeout"选项
  • 环境 NVRAM 电池已满电量容量错误不受 raid.timeout 选项控制。示例:
::>storage raid-options show -node * -name raid.timeout*
Node    Option                      Value     Constraint
node_name-1
     raid.timeout                  60      only_one
node_name-2
2 entries were displayed.
但是:
[node_name: env_mgr: nvram.battery.fcc.low:error]: The NVRAM battery full-charge capacity is low (48 %). To prevent data loss, the system will shut down in 24 hours.
[node_name: env_mgr: nvram.battery.fcc.low:error]: The NVRAM battery full-charge capacity is low (48 %). To prevent data loss, the system will shut down in 60 minutes.
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery PCT capacity low)
[node_name: env_mgr: nvram.battery.fcc.low:error]: The NVRAM battery full-charge capacity is low (48 %). To prevent data loss, the system will shut down now.
追加信息
  • 错误1226105功能请求:ONTAP 中的系统环境关闭配置控制
  • 错误1226107功能请求:SP/BMC支持ONTAP 中的系统环境关闭配置
    • 在 AFF/FAS 80x0 平台上,此功能在 ONTAP 中实施,并不依赖于服务处理器固件
