跳转到主内容
可以使用以下哪个命令监控 FlexGroup 卷上的存储效率进度?
28
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009 年 117857</a>
Last Updated:
适用场景
  • ONTAP 9.8
  • FlexGroup
问题解答
存储效率作业需要很长时间才能在大型 FlexGroup 卷上进行竞争,才能以细粒度方式检查存储效率进度:
  • SIS-STATUS-L.XML 入 ASUP 。
  • volume efficiency show -instance 只能显示整个 FlexGroup 的存储效率进度,不能显示成员卷的进度。您可以使用 diag 级别的命令来显示每个卷上的进度。
    Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for assistance with the solution.
    • The solution requires Diagnostic-level recovery.
    • The use of Diagnostic commands and recovery steps is potentially disruptive and should only be used with guidance from NetApp Support.
追加信息
请参见 TR-4571
