跳转到主内容
无法使用 ADP 重新初始化系统
127
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
适用场景
  • AFF-A220
  • 操作系统 9.8P2
  • 高级驱动器分区( ADP )
  • 高可用性( HA )对
问题描述
警告
如果节点和 HA 配对节点之间共享分区,并且将节点配置重置为出厂默认设置,则此菜单选项将擦除节点和 HA 配对节点上的磁盘上的所有数据。
  • 选项 9a/9b 后,磁盘分配失败
***OS2SP configured successfully***Jan 18 16:11:25 [localhost:cf.ic.sbb:notice]: HA interconnect: SBB Compatibility Event. Compatible partner node found. The interconnect device has been enabled.
Jan 18 16:11:38 [localhost:discover.6500.unsupported:notice]: FC-to-SAS bridge ATTO 6500N discovery is disabled.
pnso provider init started.
pnso init failed in pnso_init() : 35
hwo: Node is using hardware provider : 1.
cryptomod_fips: Executing Crypto FIPS Self Tests.
cryptomod_fips: Crypto FIPS self-test: 'CPU COMPATIBILITY' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 ECB, AES-256 ECB' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CBC, AES-256 CBC' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 GCM, AES-256 GCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'CTR_DRBG' passed.
cryptomod_fips: Crypto FIPS self-test: 'KDF' passed.
cryptomod_fips: Crypto FIPS self-test: 'SHA1, SHA256, SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'HMAC-SHA1, HMAC-SHA256, HMAC-SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'PBKDF2' passed.
cryptomod_fips: Crypto FIPS self-test: 'Self-integrity' passed.
HA Config: Chassis = non-ha Controller = non-ha
WARNING: 0 disks found!
  • 使用启动菜单中的选项 4 时,系统在未连接磁盘的情况下重新启动错误消息:
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m53s
System rebooting...
BIOS Version: 11.9
Portions Copyright (C) 2014-2018 NetApp, Inc. All Rights Reserved.
BOOTMGR: Assigned 0 out of 12 disks requested
BOOTMGR: If the disk shelves are partially populated,
Follow best practice guidelines to populate disks in the right slots
New to NetApp?
