由于 " 未从配对节点检测到检测到检测信号 " 而接管
适用场景
- AFF A300
- AFF-A220
- FAS2720
问题描述
发生接管时会同时发出以下警报:
[Node-01: ctrl_hb_port_ic0a: ctrl.rdma.heartBeat:info]: HA interconnect: Missed heartbeat to 192.0.1.5.
[Node-01: gop_eq: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is down.
[Node-01: cf_main: cf.fsm.takeoverByPartnerDisabled:error]: Failover monitor: takeover of Node-01 by Node-02 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
[Node-01: cf_main: cf.fsm.takeoverCountdown:info]: Failover monitor: takeover scheduled in 10 seconds
