跳转到主内容
节点报告splog.sp.not.accessible、防火墙阻止SP API服务的端口50000
432
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
问题描述
  • 一个节点向集群中其他节点的SP/ BMC报告 servprocd 连接问题。示例:
[node_name_03: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name_01) is not accessible because of The Service Processor on node "node_name_01" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
[node_name_03: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name_02) is not accessible because of The Service Processor on node "node_name_02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
  • 在 ONTAP或SP/ BMC固件更新
  • servprocd 守护程序和 api 服务在节点
  • HW-Assist 上重新启动后,可能会开始出现这些消息,在节点 magnamente LIF 和BMC IP 之间进行 ping 测试正常
    New to NetApp?
