跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
添加磁盘架后, SAS 适配器端口 PHY 将禁用除一个端口以外的所有端口
16
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用场景
  • 已将磁盘架 DS2246 添加到 MetroCluster 中
  • 磁盘型号 X356_TPM4V3T8AME
问题描述
  • 添加了包含磁盘型号 X357_TPM4V3T8AME 的磁盘架
  • 多个磁盘显示为故障
62.0 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX)
62.1 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.2 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.3 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.4 : NETAPP   X356_TPM4V3T8AME NA03   0.0GB   0B/    (Failed-Unsupported)
62.5 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.6 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.7 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX)
62.8 : NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
62.9 : NETAPP   X356_TPM4V3T8AME NA03    0.0GB   0B/sect (Failed-Unsupported)
62.10: NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX)
62.11: NETAPP   X356_TPM4V3T8AME NA03 3662.5GB 520B/sect (XXXXXXXXXXXX) (Failed)
  • 磁盘已重新拔插,但仍显示为出现故障
  • 适配器上的所有 SAS 端口均显示已禁用 PHY ,包括未连接到新添加的磁盘架的端口
Cluster::*> storage port show -node Node-01 *
         Cable Length: 2m
    Cable End Identifier: end_1
        Cable Identifier: 500a09800856a299-500a09800e4055f4
              Port Speed: 12 Gb/s
              Port State: enabled
             Port Status: online-degraded
              Error Type: online-degraded
          Error Severity: Error
              Error Text: The port is in online degraded state.
      Corrective Action: Check cable connections.
              Phy State: [0] disabled, offline,  0 Gb/s
                          [1] disabled  offline,  0 Gb/s
                          [2] disabled, offline,  0 Gb/s
                          [3]  enabled,  online, 12 Gb/s
  • 缆线,已重新拔插 IOM ,但问题描述 仍然存在
  • 已执行接管 / 交还,磁盘仍处于故障状态(故障 - 不支持 的驱动器不再显示为故障)
  • 已更换故障驱动器,但错误仍然存在
[Node-01: disk_server_0: disk.ioMediumError:notice]: Medium error on disk 0b.62.3: op 0x28:00000010:0008 sector 16 SCSI:medium error - Unrecovered read error - If the disk is in a RAID group, the subsystem will attempt to reconstruct unreadable data (3 11 ff 0) (4492) Disk 0b.62.3 Shelf 62 Bay 3 [NETAPP   X356_TPM4V3T8AME NA03] S/N [XXXXXXXXXXXX] UID [50000397:9C902830:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000]
[Node-01: pmcsas_timeout_0: sas.device.quiesce:debug]: Adapter 0a encountered a command timeout on disk device 0c.62.1. Quiescing the device.
[Node-01: pmcsas_timeout_0: sas.device.quiesce:debug]: Adapter 0a encountered a command timeout on disk device 0b.62.3. Quiescing the device.
[Node-01: pmcsas_timeout_0: sas.device.quiesce:debug]: Adapter 0a encountered a command timeout on disk device 0b.62.11. Quiescing the device.
New to NetApp?
Scan to view the article on your device
