由于无法在源节点上禁用BDFU、升级期间的放弃已中止、并且无法执行后续接管
适用场景
- ONTAP 9.
- 自动化无中断更新(ANDU)
- 后台磁盘固件更新(BDFU)
问题描述
- 在无中断ONTAP升级期间、HA配对节点中的第一个节点将成功升级
- 配对节点升级完成、但仍处于 部分返回状态。
cluster::*> storage failover show-giveback Partner Node Aggregate Giveback Status -------------- ----------------- --------------------------------------------- node01 CFO Aggregates Done SFO Aggregates Aborted. Failed to disable background disk firmware updates on the source node. Wait a few minutes then try the operation again. node02 No aggregates to give back
事件日志条目:
示例 1
Tue Jan 07 17:33:10 CET [cluster: cf_giveback: sfo.giveback.aborted.bdfu:error]: Giveback is aborted: node01 took more than 120 seconds to finish the background disk firmware update.
示例 2
An optimized negotiated takeover of the HA partner node by the local node has been aborted. Reason: failed to disable background disk firmware update (BDFU) on partner node
