跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
由于启动设备损坏、ONTAP 升级失败
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>20095976</a>
Last Updated:
适用场景
  • FAS25xx
  • ONTAP 9.
问题描述
尝试升级时、安装失败并显示错误:
Error: Install Failed. ERROR: Insufficient space available on device. ,
Action: Use the "cluster show" command to verify that all nodes in the cluster are healthy. Use the "cluster image package show-repository" command to verify that the downloaded image has the correct version. If all nodes are healthy and the image has the correct version, wait a few minutes, and then use the "cluster image resume-update" command to resume
the update.
New to NetApp?
Scan to view the article on your device
