跳转到主内容
ONTAP报告AFF A700或FAS9000系统上的多个传感器错误
63
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • AFF A700
  • FAS9000
  • AFF A900
  • FAS9500
问题描述
ONTAP报告AFF A700 / AFF A900 / FAS9000 / FAS9500系统上的多个传感器错误、并自动恢复。
机箱温度警报可以是"太高"或"太低"、具体取决于系统。
示例:
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Inflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Outflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS ASIC DieTemp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P3.3V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.8V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.0V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P0.9V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS 5V Standby is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P12V HS is not readable
Thu Apr 30 00:27:59 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Hot Swap Cur is not readable
Thu Apr 30 00:28:00 UTC [node: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.ioCard.ok:notice]: IO card on slot 9 is OK
Thu Apr 30 00:29:00 UTC [node: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
 Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO1 200G SW DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO1 200G CPLD DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO2 200G SW DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO2 200G CPLD DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO4 200G SW DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO4 200G CPLD DieTmp is critical low (0 C). Fri May 09 22:37:23 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO10 200G SW DieTmp is critical low (0 C). Fri May 09 22:37:24 +0700 [node: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: IO10 200G CPLD DieTmp is critical low (0 C). Fri May 09 22:37:47 +0700 [node: env_mgr: monitor.shutdown.chassisUnderTemp:error]: Chassis temperature is too cold: Temp on I/O Slot1 is critical low. System will be shutdown in 2 minutes Fri May 09 22:37:47 +0700 [node: env_mgr: monitor.shutdown.chassisUnderTemp:error]: Chassis temperature is too cold: Temp on I/O Slot4 is critical low. System will be shutdown in 2 minutes Fri May 09 22:37:48 +0700 [node: env_mgr: monitor.shutdown.chassisUnderTemp:error]: Chassis temperature is too cold: Multiple Temp sensors are critical low. System will be shutdown in 2 minutes Fri May 09 22:38:00 +0700 [node: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too low.. Fri May 09 22:38:17 +0700 [node: env_mgr: callhome.chassis.undertemp:EMERGENCY]: Call home for CHASSIS UNDER TEMPERATURE SHUTDOWN
New to NetApp?
