跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
新添加的 FIPS 磁盘报告为 " 非加密驱动器或未经 FIPS 认证的驱动器 "
2
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用场景
  • FAS
  • AFF
  • ONTAP 9
  • FIPS 驱动器
  • NSE 驱动器
  • X358_SLBPE3T8ATE
问题描述
  • 添加启用了 FIPS 的 X358_SLBPE3T8ATE 驱动器的新磁盘架后,所有驱动器均显示为故障。
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
    Firmware rev:       03.08.09.00
    Base WWN:           5:00a098:0038a6d:30
    Phy State:          [0] Enabled, 12.0 Gb/s
                        [1] Enabled, 12.0 Gb/s
                        [2] Enabled, 12.0 Gb/s
                        [3] Enabled, 12.0 Gb/s
    Mini-SAS HD Vendor:        Amphenol
    Mini-SAS HD Part Number:   112-00435+A0
    Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m ID:01
    Mini-SAS HD Serial Number: APF16454005221
     ID     Vendor   Model            FW    Size
    00.0 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.1 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.2 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.3 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.4 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.5 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.6 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.7 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.8 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.9 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.10: NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.11: NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
  • EMS 日志显示驱动器未通过 FIPS 认证:
[XXXXX:disk.encryptSupportReqd:ALERT]: Detected nonencrypting drive or non-FIPS-certified drive 0a.XX.XX, but only FIPS-certified drives are supported on this node. 84 of 96 drives checked are FIPS-certified
New to NetApp?
Scan to view the article on your device
