跳转到主内容
多个传感器报告 NS224 磁盘架上的不可用状态
37
Visibility:
Votes:
0
Category:
disk-shelves<a>2008714943</a>
Specialty:
hw
Last Updated:
适用场景
NS224 磁盘架
问题描述
  • 磁盘架上的多个传感器报告为不可用或不适用
cluster1::> system node run -node <nodename> -command environment status
Shelf status: normal condition
     SES Configuration, shelf 0:
     logical identifier=XXXXXXXXXXXXXXXXXX
     vendor identification=NETAPP
     product identification=NS224NSM100
     product revision level=0131
     Vendor-specific information:
     Product Serial Number: XXXXXXXXXXXXXXX
     Power Supply installed element list: 2; with error: none
    Power Supply information by element:
      [1] Serial number: <N/A> Part number: <N/A>
        Type: <N/A>
        Firmware version: <N/A>
        Swaps: 0
      [2] Serial number: XXXXXXXXXXXXXX  Part number: DPS-1600AB-18 C
        Type: 00
        Firmware version: 00.15.04
        Swaps: 0
    Voltage Sensor installed element list: 2; with error: none
     Shelf voltage by element:
     [1] Unavailable
      [2] 12.01 Volts  Normal voltage range
    Current Sensor installed element list: 2; with error: none
     Shelf current by element:
     [1] Unavailable
      [2] 18980 mA  Normal current range
     Cooling Unit installed element list: 11, 12, 13, 14, 15, 16, 17, 18, 19, 20; with error: none
    Cooling Units by element:
      [1] Unavailable
      [2] Unavailable
      [3] Unavailable
      [4] Unavailable
      [5] Unavailable
      [6] Unavailable
      [7] Unavailable
      [8] Unavailable
      [9] Unavailable
      [10] Unavailable
      [11] 6780 RPM
      [12] 6440 RPM
      [13] 6400 RPM
      [14] 6510 RPM
      [15] 6480 RPM
      [16] 8270 RPM
      [17] 7820 RPM
      [18] 7950 RPM
      [19] 8150 RPM
      [20] 8140 RPM
    ES Electronics information by element:
        CPLD version: <N/A>
 Swaps: 0
      [2] Serial number: XXXXXXXXXXXX  Part number: 111-04256+B4
        CPLD version: 1F  Swaps: 0
  • 所有受影响的传感器都位于同一模块上。
New to NetApp?
