跳转到主内容
FAS9000 或 AFF A700 报告 NVRAM 电池电流低于正常值( -50 mA )
70
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • FAS 9000
  • AFF A700
  • FAS 9500
问题描述
  • 'current is below normal(-50 mA)'  'current is normal' 在EMS日志中、警告消息后面会在一分钟内显示一条消息:
示例:
3/30/2022 02:20:54 [HOSTNAME: env_mgr: nvram.battery.current.low.warn:error]: The NVRAM battery current is below normal (-50 mA). To prevent data loss, the system will shut down in 24 hours. 3/30/2022 02:21:44 [HOSTNAME: env_mgr: nvram.battery.current.normal:info]: The NVRAM battery current is normal.
  •  服务处理器(SP)系统事件日志显示以下信息:
示例:
Tue Mar 29 17:20:39.240363 2022 [IPMI.notice]: 7906 | 02 | EVT: 01505194 | VBAT_P8V | Assertion Event, "Lower Non-critical going low " | Reading: 4.050 | Threshold: 7.400 Tue Mar 29 17:20:39.520112 2022 [IPMI.notice]: 7a06 | 02 | EVT: 0152518c | VBAT_P8V | Assertion Event, "Lower Critical going low " | Reading: 4.050 | Threshold: 7.000 Tue Mar 29 17:20:51.084355 2022 [IPMI.notice]: 7b06 | 02 | EVT: 0150ffff | Bat_Curr | Assertion Event, "Lower Non-critical going low " | Reading: -0.050 | Threshold: -0.050 Tue Mar 29 17:20:51.436129 2022 [IPMI.notice]: 7c06 | 02 | EVT: 6f02ffff | NVS_Status | Assertion Event, "Fault" Tue Mar 29 17:20:52.439646 2022 [IPMI.notice]: 7d06 | 02 | EVT: 8152998c | VBAT_P8V | Deassertion Event, "Lower Critical going low " | Reading: 7.650 | Threshold: 7.000 Tue Mar 29 17:20:52.484358 2022 [IPMI.notice]: 7e06 | 02 | EVT: 81509994 | VBAT_P8V | Deassertion Event, "Lower Non-critical going low " | Reading: 7.650 | Threshold: 7.400 Tue Mar 29 17:20:52.976359 2022 [IPMI.notice]: 7f06 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted" Tue Mar 29 17:21:27.692359 2022 [IPMI.notice]: 8006 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault" Tue Mar 29 17:21:33.572444 2022 [IPMI.notice]: 8106 | 02 | EVT: 6f02ffff | Bat_Status | Assertion Event, "Fault" Tue Mar 29 17:21:33.836368 2022 [IPMI.notice]: 8206 | 02 | EVT: 815027ff | Bat_Curr | Deassertion Event, "Lower Non-critical going low " | Reading: 1.950 | Threshold: -0.050 Tue Mar 29 17:21:34.784604 2022 [IPMI.notice]: 8306 | 02 | EVT: ef02ffff | NVS_Status | Deassertion Event, "Fault" Tue Mar 29 17:21:42.808354 2022 [IPMI.notice]: 8406 | 02 | EVT: ef02ffff | PCM_Status | Deassertion Event, "Fault" Tue Mar 29 17:22:22.994656 2022 [IPMI.notice]: 8506 | 02 | EVT: ef02ffff | Bat_Status | Deassertion Event, "Fault" Tue Mar 29 17:22:25.220348 2022 [IPMI.notice]: 8606 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted" Tue Mar 29 17:25:09.649861 2022 [IPMI.notice]: 8706 | 02 | EVT: 6f08ffff | Bat_Status | Assertion Event, "Learn Cycle" Tue Mar 29 18:40:36.732115 2022 [IPMI.notice]: 8806 | c0 | OEM: f9ff7020ff5e | ManufId: 150300 | Undefined Tue Mar 29 18:55:07.545729 2022 [IPMI.notice]: 8906 | 02 | EVT: ef08ffff | Bat_Status | Deassertion Event, "Learn Cycle" Tue Mar 29 20:02:14.848115 2022 [IPMI.notice]: 8a06 | c0 | OEM: f9ff7020ff5c | ManufId: 150300 | Undefined Tue Mar 29 23:36:54.085744 2022 [IPMI.notice]: 8b06 | c0 | OEM: f9ff7020ff57 | ManufId: 150300 | Undefined
New to NetApp?
