system node power show失败、由于VLAN标记、节点上的服务处理器无法访问
适用场景
- BMC
- service-processor API-service
- 集群管理LIF不在专用管理端口e0M中
问题描述
- 发出
system node power show""时出错。
示例:
::> system node power show
Node Status
node_name-01 on
Error: The Service Processor on node "node_name-02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again.
node_name-02 -
- EMS/事件错误消息。
示例:
[node_name-01: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name-02) is not accessible because of The Service Processor on node "node_name-02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
SP-MGMT-MLOG-TXT.GZ AutoSupport部分超时错误。
示例:
[kern_servprocd:info:7038] Thrift: Mon Jul 11 14:43:50 2022 TSocket::open() timed out <Host: 123.123.123.123 Port: 50000>
[kern_servprocd:info:7038] ERR: Servprocd::CLI: system_power_status_worker : TTX ERROR: 1 (open() timed out)
system node power show当连接到节点管理LIF而不是集群管理LIF时、命令有效。storage failover hwassist show报告活动和运行状况良好的输出- 命令
system service-processor api-service show显示已启用、但使用内部证书。 - 与节点管理LIF相比、集群管理LIF的IP地址具有不同的子网掩码。
示例:
Cluster1::> net int show -role *mgmt*
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
Cluster1
cluster_mgmt up/up 10.XXX.XXX.130/23 Node-1 e2a false
node1_mgmt up/up 10.XXX.XXX.128/24 Node-1 e2a true
node2_mgmt up/up 10.XXX.XXX.139/24 Node-2 e0M true
