跳转到主内容
node_name 无法进行紧急控制器故障转移。日志未同步
170
Visibility:
Votes:
1
Category:
aff-series<a>未同步日志</a><a>2008723333</a><a>ic6a</a><a>BURT 1396573</a>
Specialty:
hw
Last Updated:
适用场景
  • AFF A700
  • FAS9000
  • ONTAP 9
问题描述
  • EMS紧急消息:
Sun Apr 18 09:50:00 +0200 [node_name_1: monitor: monitor.globalStatus.critical:EMERGENCY]: Controller failover of node_name_2 is not possible: unsynchronized log.
  • 这是一个瞬时问题描述、不是永久性的。
  • 已启用存储故障转移。
  • 系统运行状况良好、不存在运行状况警报。
  • 事件日志示例:
Time        Node     Severity Event
4/8/2021 08:29:18 node_name_1 ERROR   cf.fsm.takeoverByPartnerDisabled: Failover monitor: takeover of node_name_1 by node_name_2 disabled (unsynchronized log).
4/8/2021 08:29:18 node_name_1 ERROR   cf.fsm.takeoverOfPartnerDisabled: Failover monitor: takeover of node_name_2 disabled (unsynchronized log).
4/8/2021 08:29:16 node_name_1 ERROR   cf.fsm.takeoverOfPartnerDisabled: Failover monitor: takeover of node_name_2 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
4/8/2021 08:29:15 node_name_1 ERROR   cf.fsm.takeoverByPartnerDisabled: Failover monitor: takeover of node_name_1 by node_name_2 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
4/8/2021 07:49:11 node_name_1 ERROR   cf.fsm.takeoverByPartnerDisabled: Failover monitor: takeover of node_name_1 by node_name_2 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
4/8/2021 07:49:11 node_name_1 ERROR   cf.fsm.takeoverOfPartnerDisabled: Failover monitor: takeover of node_name_2 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
  • 在两个节点中对互连链路问题描述进行转接:
Sun Apr 18 07:47:41 +0200 [node_name_1: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is down.
Sun Apr 18 07:47:44 +0200 [node_name_1: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is up.
Sun Apr 18 09:49:46 +0200 [node_name_1: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is down.
Sun Apr 18 09:49:49 +0200 [node_name_1: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is up.
Sun Apr 18 07:47:41 +0200 [node_name_2: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is down.
Sun Apr 18 07:47:44 +0200 [node_name_2: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is up.
Sun Apr 18 09:49:46 +0200 [node_name_2: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is down.
Sun Apr 18 09:49:49 +0200 [node_name_2: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic6a link is up.
...(英文)。
New to NetApp?
