跳转到主内容
AFF A800两个NVDIMM均出现故障、并在启动时显示NVMEM电池不存在
68
Visibility:
Votes:
2
Category:
aff-series
Specialty:
HW
Last Updated:
适用场景
AFF A800
问题描述
  • AFF A800节点无法启动、并且两个NVDIMM均发生故障且电池不存在:
Loading NVDIMM0 firmware version 2.6.2.c (was 2.5.3.c)
Programming NVDIMM0 FW. This could take over 8 minutes. Please wait...
Fri Dec 11 04:59:56 2020 [nvdimm.fw.upgrade.failure:ERROR]:NVDIMM controller in slot-11 failed to upgrade firmware because it is at ARMed state or has valid data
Loading NVDIMM1 firmware version 2.6.2.c (was 2.5.3.c)
Programming NVDIMM1 FW. This could take over 8 minutes. Please wait...
Fri Dec 11 04:59:56 2020 [nvdimm.fw.upgrade.failure:ERROR]:NVDIMM controller in slot-23 failed to upgrade firmware because it is at ARMed state or has valid data
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary
conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter'
Dec 11 05:01:59 [localhost:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
CAUTION: Using this appliance without NVRAM
battery backup coupled with a power
failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)? y
Dec 11 05:02:30 [localhost:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • 在后续启动时、两个NVDIMM都会报告错误情况:
BIOS Version: 13.5
PEI start.
CPU PEI initialization.
Wait BMC self-test result.
BMC self-test: OK.
Running full memory initialization.
DIMM F1: NVDIMM in ERROR condition (0x00000801).
DIMM M1: NVDIMM in ERROR condition (0x00000801).
  • 运行诊断测试时、其他组件通过测试、但电池出现故障:
Battery: FAILED
Expect: 1 Present: 0
Unable to send RAW command (channel=0x0 netfn=0x34 lun=0x0 cmd=0x71 rsp=0xce): Command response could not be provided
Battery VPD:
Manufacturer Name :
Manufacturer Date :
Device Chemistry :
New to NetApp?
  • 这篇文章对您有帮助吗?
