跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
AFF-A400:"环境原因停机(电池仍为容量关键型)"
8
Visibility:
Votes:
0
Category:
aff-series<a>2008963050</a>
Specialty:
hw
Last Updated:
适用场景
  • AFF-A400/FAS8300
  • BMC 固件 13.5+
问题描述
  • 在电池学习周期内,由于 NVMEM 电池容量严重不足,节点重新启动,但电池在重新启动后报告正常。
Oct 28 20:11:23 [ntap1-10: env_mgr: nvmem.battery.capLowCrit:EMERGENCY]: The NVMEM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 20 minutes.
Oct 28 20:12:23 [ntap1-10: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
Oct 28 20:20:31 [ntap1-10: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (17 %). To prevent data loss, the system will shut down in 20 minutes.
Oct 28 20:21:31 [ntap1-10: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
Oct 28 20:31:23 [ntap1-10: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery remain capacity critical)
  • BMC 事件日志显示电池学习周期正在进行中。
    d2 | 10/28/2021 | 18:16:27 | Battery Learning #0xc4 | In progress | Asserted
    d3 | 10/29/2021 | 00:11:19 | Battery #0x49 | Lower Non-critical going low
    d4 | 10/29/2021 | 00:11:29 | Battery #0x49 | Lower Critical going low
    d5 | 10/29/2021 | 00:31:56 | OS Stop/Shutdown #0xff | OS graceful shutdown | Asserted
    d6 | 10/29/2021 | 00:31:57 | Power Unit #0xb2 | Power off/down | Asserted | from channel 15
    d7 | 10/29/2021 | 00:32:19 | Battery #0x49 | Lower Non-critical going low
    d8 | 10/29/2021 | 00:33:00 | Battery #0x49 | Lower Critical going low
    d9 | 10/29/2021 | 00:33:37 | Battery Learning #0xc4 | In progress | Asserted
    da | 10/29/2021 | 05:21:16 | Battery #0x49 | Lower Critical going low
    db | 10/29/2021 | 05:25:11 | Battery #0x49 | Lower Non-critical going low
    dc | 10/29/2021 | 16:32:09 | Power Unit #0xb2 | Power on | Asserted | from channel 1
    dd | 10/29/2021 | 16:33:12 | System Firmware Progress | Secondary CPU Initialization | Asserted
    de | 10/29/2021 | 16:33:12 | System Firmware Progress | USB resource configuration | Asserted
    df | 10/29/2021 | 16:33:15 | System Firmware Progress | PCI resource configuration | Asserted
    e0 | 10/29/2021 | 16:33:20 | System Firmware Progress | Video initialization | Asserted
    e1 | 10/29/2021 | 16:33:20 | System Firmware Progress | Keyboard controller initialization | Asserted
    e2 | 10/29/2021 | 16:33:21 | System Firmware Progress | Hard-disk initialization | Asserted
    e3 | 10/29/2021 | 16:33:40 | System Event |  | Asserted
New to NetApp?
Scan to view the article on your device
