跳转到主内容
由于bootarg.pegasus.nvmefor.storage_ports配置不当、在更换启动设备后"进入FM状态:5"
69
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw<a>FSE</a><a>2009066800</a>
Last Updated:
适用场景
  • NS224 磁盘架
  • ONTAP 9
问题描述
在对 [1] AFF 型号执行启动设备更换操作步骤 后,节点将返回到等待交还状态;但是,控制台上会持续显示以下消息。
  • 在对AFF型号执行启动设备更换操作步骤之后、ONTAP无法启动。控制台上会持续显示以下消息:
Entering FM state:5 because mbFound:0 local in headswap:0
Waiting for giveback...(Press Ctrl-C to abort wait)
Waiting for giveback...(Press Ctrl-C to abort wait)Entering FM state:5 because mbFound:0 local in headswap:0
This node was previously declared dead.
Pausing to check HA partner status ...
lock was released, continuing boot ...
WARNING: 0 disks found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
  • 命令""disk show -v将生成以下内容:
*> disk show -v
 Local System ID: ********
disk show: No disks attached to system.
  • 命令""storage port show显示端口状态为disabled:
*> storage port show
 Port  Type   Speed(Gb/s)   State       Status   VLAN ID  Is Dedicated?
e0c   ENET   100 Gb/s    disabled      online   0     false
e0d   ENET   100 Gb/s    disabled      online   0     false
e5a   ENET   100 Gb/s    disabled      online   0     false
e5b   ENET   100 Gb/s    disabled      online   0     false
查看 clustershell 中的 storage failover show 输出会将状态问题描述 显示为 "Kernel loaded" :
                Takeover
Node       Partner     Possible State Description
cluster1-01   cluster1-02 true    Connected to cluster1-02
cluster1-02   cluster1-01 true    Kernel loaded
2 entries were displayed.
New to NetApp?
