跳转到主内容
FlexArray for NetApp 控制器升级 / 更换涉及哪些具体步骤?
19
Visibility:
Votes:
0
Category:
v-series-flexarray
Specialty:
virt
Last Updated:
适用于
FlexArray
解答
Description:
‘Hardware upgrade’ and ‘Controller replacement’ documents available in NetApp support site explain in detail regarding the steps involved during controller upgrades/replacements. This article is to only emphasize the importance of few pre and post steps required during such operations on systems involving FlexArray.
Details:
Upgrade/replacement procedures are broadly classified into three categories:
Case 1: Upgrading controller hardware by moving storage
Case 2: Replacing the controller module
Case 3: Upgrading controller hardware by moving volumes
 Before upgrading/replacing:
  1. Gather the following information from the original node:
    • License information
      system license show
      Obtain new license keys for the new nodes from the NetApp Support Site at mysupport.netapp.com.
    • Topology of the system - note the switch/zoning information
      storage array config show -switch
    • Note down the port configurations:
      ucadmin show
  2. Label all cables from the original nodes before removing
After installation:
For cases 1 and 2: While setting up the new node:
For case 3: After volume movement:
  1. Transfer cables from the original nodes to the new ones.
  2. Restore the port configurations as before.
  3. Run the following command from the Maintenance mode:
    ucadmin modify -m {fc|cna} -t {initiator|target} adapter-name
  4. Modify the zones with new wwpns.
其他信息
附加信息 _text
