跳转到主内容
磁盘故障 LED 指示灯亮起、并且“机柜旁路 B ”
50
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
适用于
  • DS224C
  • DS4246
问题
  • 磁盘故障 LED 指示灯亮起。
  • ENCLOSURE BYPASSED B 可以在以下命令输出中找到错误事件。
示例:
> storage show fault -v
Enclosure Status: non-critical
Channel: 3c
Shelf: 1
Shelf Type: DS4246
Product Serial Number: XXXXXXXXXXXX
Module Type: IOM6
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
 19 [Bay 19]: OK                01,13,00,00
 20 [Bay 20]: NONCRITICAL       03,14,10,04   ENCLOSURE BYPASSED B, BYPASSED B
 21 [Bay 21]: OK                01,15,00,00
  • 输出中的两条路径sysconfig -a均显示磁盘状态为正常。
示例:
 slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
  Firmware rev:       01.11.00.00
  Base WWN:           5:00a098:0014dc6:88
  Phy State:          [0] Enabled, 6.0 Gb/s
                      [1] Enabled, 6.0 Gb/s
                      [2] Enabled, 6.0 Gb/s
                      [3] Enabled, 6.0 Gb/s
  QSFP Vendor:        Molex Inc.
  QSFP Part Number:   112-00176+A0
  QSFP Type:          Passive Copper 0.5m ID:00
  QSFP Serial Number: 235621256
                01.19: NETAPP   X308_SMNRY03TSSA NA00 2538.5GB 512B/sect (Z297CDM7)
                01.20: NETAPP   X308_THARR03TSSM NA00 2538.5GB 512B/sect (16S3K7ZUF)
                01.21: NETAPP   X308_THARR03TSSM NA00 2538.5GB 512B/sect (16SDK6P1F)
 slot 3: SAS Host Adapter 3c (PMC-Sierra PM8001 rev. C, SAS, <UP>)
  MFG Part Number:    USI 6086-000010-07 rev. MP V4.10
  Part number:        111-00341+F2
  Serial number:      ST063D3S0F2
  Date Code:          20130325
  Base WWN:           5:00e004:00027f4:b0
  QSFP Type:          Passive Copper 0.5m ID:01
  QSFP Serial Number: 235621280
  • 确认sysconfig-r磁盘是备用磁盘。
示例:
Spare disks
RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
Spare disks for block checksum
spare   0a.01.20 0a    1   20  SA:A   -  BSAS  7200 2538546/5198943744 2543634/5209362816
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
