跳转到主内容
临时 vifmgr.port.monitor.failed 错误。未通过 "l2_reachable" 运行状况检查
51
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
MetroCluster
Last Updated:
适用场景
  • FAS/AFA
  • ONTAP 9
  • 集群网络交换机(CNS) Cisco Nexus N3K-C3132Q-V
  • MetroCluster-IP (MCC IP)
问题描述
  • 不同节点和端口中的多条临时L2可访问性EMS消息。示例:
Thu Dec 03 15:57:33 +0100 [node_name: ctran_clam_0: ems.engine.suppressed:debug]: Event 'csm.connCookieNotFound' suppressed 19 times in last 702 seconds.
Thu Dec 03 15:57:33 +0100 [node_name: ctran_clam_0: csm.connCookieNotFound:debug]: Session (req=cc51A:dblade, rsp=node_name:dblade, uniquifier=0b05b2e186d65fb2): connection cookie 1011 is invalid.
Thu Dec 03 15:57:38 +0100 [node_name: vifmgr: vifmgr.bcastDomainPartition:error]: Broadcast domain Cluster is partitioned into 2 groups on node node_name. The different groups are: {e0a}, {e0b}. LIFs hosted on the ports in this broadcast domain may be at the risk of seeing connectivity issues.
Thu Dec 03 15:57:44 +0100 [node_name: vifmgr: vifmgr.port.monitor.failed:error]: The "l2_reachability" health check for port e0a (node node_name) has failed. The port is operating in a degraded state.
Thu Dec 03 15:57:44 +0100 [node_name: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: Insufficient L2 Reachability - Insufficient L2 Reachability detected from cluster port e0a on node node_name.
Thu Dec 03 15:57:44 +0100 [node_name: vifmgr: vifmgr.portDeg.lifMoved:notice]: LIF node_name-clus1 (on virtual server 4294967293), IP address 169.254.114.29, is being moved to node node_name, port e0b from node node_name, port e0a because the port's health status is in a degraded state.
Thu Dec 03 15:57:46 +0100 [node_name: vifmgr: vifmgr.lifsuccessfullymoved:notice]: LIF node_name-clus1 (on virtual server 4294967293), IP address 169.254.114.29, is now hosted on node node_name, port e0b.
Thu Dec 03 15:57:46 +0100 [node_name: vifmgr: vifmgr.port.monitor.passed:notice]: The "l2_reachability" health check for port e0a (node node_name) has passed.
Thu Dec 03 15:57:46 +0100 [node_name: vifmgr: vifmgr.portHealthy:notice]: The health status of port e0a (node node_name) has changed from degraded to healthy. This port can now be used for hosting LIFs.
  • 报告问题的集群端口在中显示为关闭 SYSCONFIG -A
slot 0: 10 Gigabit Ethernet Controller IX5-SFP+
  e0a MAC Address:   XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
    SFP Vendor:      AVAGO
    SFP Part Number:   AFBR-709SMZ-NA4
    SFP Serial Number:  XXXXXXXXXXXX
  • 报告问题的集群端口 连接到不同的MCC IP 集群网络交换机(CNS)。
  • MCC IP 集群网络交换机 正在 运行兼容的固件和RCC文件。
  • 交换机 日志""中未报告问题# show tech-support
  • 端口和VLAN的ifstat输出未报告任何问题。
New to NetApp?
