跳转到主内容
BES-53248 交换机出现 CSM-mismatchRemoteDevice 错误事件
4
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009063253</a>
Last Updated:
适用场景
  • ONTAP 9
  • 有交换机集群配置(包括MetroCluster IP)
  • 运行 EFOS 固件版本 <3.9 的 BES-53248 交换机
  • Cisco 发现协议( CDP )
  • ONTAP 集群会话管理器( CSM )
问题描述
  • ONTAP 事件日志记录了 CSM-mismatchRemoteDevice 错误事件:
Thu Feb 17 11:52:05 +0100 [node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1023 and destination address 169.254.13.13 might not be optimal for session 00001111deadbeef. The source is currently connected to - remote device and the destination is currently connected to myONTAPCluster remote device.
  • 上述错误中引用的 IP 地址,即169.254.13.13,是来自此集群中另一节点的集群 LIF
  • 报告上述错误事件的受影响节点 Csum Errors 会显示在 CDP 节点统计信息中
  • 重置 CDP 节点统计信息后 Packets ,计数器会在每个集群网络端口上每分钟增加 1 个数据包, Csum Errors 同时也会同时增加
::> system node run -node node-01 -command cdpd show-stats
RECEIVE
Packets:           422k | Csum Errors:       422k | Unsupported Vers:    0
Invalid length:      0  | Malformed:           0  | Mem alloc fails:     0
Missing TLVs:        0  | Cache overflow:      0  | Received Own Adv:    0
Other errors:        0  | Unknown TLV:         0  | Ejected entries:     0
Eject failed:        0  | Bad Value:           0
TRANSMIT
Packets:         87956  | Xmit fails:          0  | No hostname:         0
Packet truncated:    0  | Truncate fails:      0  | Mem alloc fails:     0
Other errors:        0
OTHER
Init failures:       0
::> system node run -node node-01 cdpd zero-stats
1 entry was acted on.
::> system node run -node * cdpd show-stats
Node: node-01
RECEIVE
 Packets:             8  | Csum Errors:         8  | Unsupported Vers:    0
TRANSMIT
 Packets:             0  | Xmit fails:          0  | No hostname:         0
 Other errors:        0
OTHER
 Init failures:       0
New to NetApp?
Scan to view the article on your device
