跳转到主内容
ONTAP FC端口显示低接收功率(RX)值
47
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
适用场景
  • ONTAP
  • FCP
  • Brocade SAN 交换机
  • Cisco SAN 交换机
问题描述
  • 根据fcp adapter show 输出、FC端口在ONTAP上显示的RX值较低:
::> fcp adapter show -instance -node nodename -adapter 0a [...] Received Optical Power: 241.3 (uWatts) Is Received Power In Range: false SFP Transmitted Optical Power: 600.4 (uWatts) Is Xmit Power In Range: true DDM Status: 30 Is Xmit Disabled: false  Is Xmit In Fault: false Is Receiver In LOS: false
  • FCP-Adapter.xml 登录 ONTAP报告低Rx功率,指示问题描述上游到ONTAP:
  • AIQM-中报告的风险低于
    •  RISK: SFP receive power of the SFP connected to netapp port 9c is below the recommended value.
•SFP在两端均显示良好。在两端、Tx和Rx均在建议范围内。
  • EMS 日志中、我们观察到link break detectedlink up 错误以及 AEN 错误:
Wed Apr 12 03:42:08 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.slifct.linkBreak:error]: Link break detected on Fibre Channel target HBA 2c with event status 1 , topology type 1, status1 0x0, status2 0x0.
Wed Apr 12 03:42:09 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.hwpfct.linkUp:notice]: Link up on Fibre Channel target adapter 2c.
fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0x1002 MboxStatus2 0xa1
  • 从Brocade交换机的sfpshow 日志中:
RX Power:   -1.9   dBm (647.5uW)
TX Power:   -4.6   dBm (349.3 uW)
  • `show interface brief`logs 在连接到受影响NetApp端口的Cisco交换机上、交换机端口状态报告为"errDisabled "
Interface  Vsan   Admin  Admin   Status     SFP   Oper  Oper   Port    Logical
          Mode   Trunk             Mode  Speed  Channel   Type
             Mode                (Gbps)
fc1/27    3    auto   off   errDisabled swl   --    --    --     --
  • show int transceiver detail Cisco交换机上的输出报告Tx功率低、表示交换机端SFP存在问题:
   SFP Diagnostics Information:
                   Alarms          Warnings
                 High     Low      High      Low
  Temperature   40.16 C      75.00 C    -5.00 C    70.00 C     0.00 C
  Voltage     3.33 V       3.63 V    2.97 V    3.46 V     3.13 V
  Current     0.00 mA      12.00 mA    4.00 mA   11.20 mA     4.80 mA
 Tx Power    -40.00 dBm     5.00 dBm  -12.20 dBm   2.00 dBm    -8.20 dBm
  Rx Power    -0.49 dBm      5.00 dBm  -15.20 dBm   2.00 dBm   -11.20 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
  • Cisco交换机上端口的Rx和Tx值显示为最佳、且端口状态为已启动。
fc2/42 is up
Temperature 38.33 C, Voltage 3.38 V, Current 6.54 mA, TxPower -6.08 dBm, RxPower -3.11 dBm
  • 交换机端的端口已切换、但NetApp端的FC端口上的Rx电源仍低。
Tue May 28 23:35:39 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 (SUCCESS)
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to down
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; shutdown (SUCCESS)
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to up
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; no shutdown (SUCCESS)
  • System Manager中的适配器吞吐量较低
  • 作为故障排除的一部分、可以执行以下步骤:
    • ONTAP上的低RX通常表示  传输端(交换机/配线板)存在硬件故障
    • 执行电缆测试以及配线板、以检查电缆是否运行正常
    • 将电缆交换至交换机端另一个打开的工作端口、以查看问题是否出在该端口上
    • 清洁电缆和两个SFP上的连接
New to NetApp?
