跳转到主内容
错误:40G收发器不支持25g-4x和50g-2x的分支映射
10
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches<a>2009238181</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP
  • Nexus N9K-C9336C-x2
  • 参考配置文件( RCF )
问题描述
  • 新安装后、集群交换机端口会增加错误:
$ ssh admin@10.10.10.150 "show interface counters errors non-zero"
Port      Align-Err   FCS-Err   Xmit-Err   Rcv-Err  UnderSize OutDiscards
Eth1/7        231      0      78     231      0       0
Eth1/8        292      0      81     292      0       0
Eth1/9        218      0     172     221      0       0
Eth1/10        223      0     165     226      0       0
Port      Single-Col  Multi-Col   Late-Col  Exces-Col  Carri-Sen     Runts
Port      Giants SQETest-Err Deferred-Tx IntMacTx-Er IntMacRx-Er Symbol-Err
Eth1/7       231      --       0      78       0      0
Eth1/8       292      --       0      81       0      0
Eth1/9       221      --       0      172       0      0
Eth1/10      226      --       0      165       0      0
  • 发现集群交换机端口上的MTU设置为1500:(示例端口)
switch# show int e1/7
Ethernet1/7 is up
admin state is up, Dedicated Interface
  Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: b8a3.771c.048
c (bia b8a3.771c.048c)
 MTU 1500 bytes, BW 40000000 Kbit , DLY 10 usec
  reliability 255/255, txload 1/255, rxload 1/255
  • 发现即使在写入擦除和重新加载之后也未应用RCF
`switch# config terminal`
`switch(config)# banner motd #`
`switch(config)# interface breakout module 1 port 1-3 map 10g-4x`
`switch(config)# interface breakout module 1 port 4-6 map 25g-4x`
Error: Breakout maps of 25g-4x and 50g-2x are not supported on 40G transceivers
`switch(config)# interface e1/1/1-4, e1/2/1-4, e1/3/1-4, e1/4/1-4, e1/5/1-4, e1/6/1-4, e1/7-34`
Invalid range at '^' marker.
`switch(config)# inherit port-profile CLUSTER`
  • 错误将持续到 RCF 行完成:
% Invalid command at '^' marker.
`switch# end`
`switch# end`
Copy complete, now saving to disk (please wait)...
Copy complete.
New to NetApp?
