跳转到主内容
SwitchSNMPCommunication_Alert 由于 SNMP 设置无效
167
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
core
Last Updated:
适用于
  • ONTAP 9
  • 集群网络交换机
  • 集群交换机运行状况监控 (CSHM)
问题
  • 集群交换机的运行状况监视器警报。示例:
[Node-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchSNMPCommunication_Alert , Alerting Resource = ClusterSW1 raised by monitor ethernet-switch
  • 报告的受监控集群交换机的 SNMP 无效设置。示例
::> system switch ethernet show
Switch              Type              Address          Model
sw1(FOC1XXXX678)    cluster-network    10.10.10.10      OTHER
     Serial Number: Unknown
     Is Monitored: false
            Reason: Invalid SNMP Settings
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4)
    Version Source: CDP
sw2(FOC1XXXX679)     cluster-network    10.10.10.10      OTHER
     Is Monitored: false
    Version Source: CDP
  • 尝试从监视和添加中删除交换机失败,出现以下错误:
::> system cluster-switch create -device cluster-switch2 -address 184.X.XX.XX -snmp-version SNMPv2c -community cshm1! -model OTHER -type cluster-network -is-monitoring-enabled-admin true
Error: SNMP validation request timed out. Verify that the "-community-or-username" value is valid.
New to NetApp?
