跳转到主内容
Nexus 9K交换机和分支缆线发生集群设置错误
82
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
HW
Last Updated:
适用场景
  • 初始集群设置配置
  • Nexus N9K-C9335C-FX交换机、运行10.2 (3)、带有4根25 Gb分支缆线和RCF 1.8。
  • 具有非分支接口和RCF 1.6的Nexus N9K-C9336-FX交换机
问题描述
  • 创建集群时显示错误消息:
Step 1 of 5: Create a Cluster
You can type "back", "exit", or "help" at any question.
Creating cluster
System start up Jan 01 00:01:00
[node_name-01:monitor.globalStatus.critical:EMERGENCY]: Controller failover of node_name-02 is not possible: Controller Failover takeover disabled.
Starting cluster support services Error: Not all local cluster ports have reachability to one another. Use the "network port reachability show -detail" command for more details. Resolve the issue, then try the command again.
  • ActiveIQ System Manager消息:
"The partner node details were not found for the node with the following serial number: 012345678910. If all the nodes were not found, then check the node connections, reload the cluster setup wizard, and then try to set up the cluster again."
New to NetApp?
