重命名集群交换机后的ClusterSwitchConnectivity_Alert
适用场景
- FAS 系统
- AFF 系统
- 交换集群
问题描述
- 在中
SYSTEM-HEALTH-ALERT.XML
Node node-2
Monitor ethernet-switch
Alert ID ClusterSwitchConnectivity_Alert
Alerting Resource node-1
Subsystem Switch-Health
Indication Time Fri Feb 06 14:50:37 2021
Perceived Severity Major
Probable Cause Configuration_error
Description One or more nodes are not connected to both cluster switches.
Corrective Actions Verify that the switch "switchA" is connected
to the node "node-1".
Possible Effect If one cluster switch fails, "node-1" might lose access to the cluster.
Acknowledge false
Suppress false
Policy ClusterSwitchConnectivity_Policy
Acknowledger
Suppressor
Additional Information
Node Name: node-1
Missing Switch: switchA
Alerting Resource Name node-1
Additional Alert Tags
- 在中
EMS-LOG-FILE.GZ
node-2: cshmd: hm.alert.raised:alert]: Alert Id = ClusterSwitchConnectivity_Alert , Alerting Resource = node-1 raised by monitor ethernet-switch
node-2: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: ClusterSwitchConnectivity_Alert[node-1].
- 在中
DEVICE-DISCOVERY.XML
Node Protocol Port Discovered Discovered Device Discovered Device Discovered Device Discovered Device
Device Interface IP Addresses Platform Version
node-1 cdp e0a sw01 0/5 10.10.10.01 CN1610 1.3.0.3
node-1 cdp e0b sw02 0/5 10.10.10.02 CN1610 1.3.0.3
- 在中
CSHM-SWITCH-CONFIG.XML
Device Name IP Address Model to display Switch Network
switchA 10.10.10.01 CN1610 cluster-network
switchB 10.10.10.02 CN1610 cluster-network
