Brocade交换机上报告了机箱警告C4-1006和严重C4-1010消息
状态信息
适用场景
- Brocade (DCX)
- X6主管
问题描述格式
- 交换机上的一个端口刀片式服务器进入禁用状态、并在errdump下报告以下错误:
2020/01/22-19:07:06, [C4-1010], 433, SLOT 2 | CHASSIS, CRITICAL, DCX, S12,C0: Above normal hardware errors were observed: fault1:0x1, fault2:0x64 thresh2:0xb0000064.
2020/01/22-19:20:41, [C4-1006], 434, SLOT 2 | CHASSIS, WARNING, DCX, S12,C0: Various non-critical hardware errors were observed: fault1:0xa, fault2:0x64 thresh1:0xa000000a.
- 在上面的示例中、插槽2 CP报告了此错误、它正在监控交换机、但报告插槽12 (S12)芯片0上的刀片式服务器上存在问题描述。
HAshow
将当前活动CP报告为插槽2:
Local CP (Slot 2, CP1): Active, Warm Recovered
Remote CP (Slot 1, CP0): Standby, Healthy
HA enabled, Heartbeat Up, HA State synchronized
slotshow -m
显示受影响插槽(此处的插槽12根据上述日志段)上的刀片式服务器运行状况良好。
slotshow -m:
Slot Blade Type ID Model Name Status
1 CP BLADE 175 CPX6 ENABLED
2 CP BLADE 175 CPX6 ENABLED
3 SW BLADE 178 FC32-48 ENABLED
4 SW BLADE 178 FC32-48 ENABLED
5 SW BLADE 178 FC32-48 ENABLED
6 SW BLADE 178 FC32-48 ENABLED
7 CORE BLADE 177 CR32-8 ENABLED
8 CORE BLADE 177 CR32-8 ENABLED
9 SW BLADE 178 FC32-48 ENABLED
10 SW BLADE 178 FC32-48 ENABLED
11 SW BLADE 178 FC32-48 ENABLED
12 SW BLADE 178 FC32-48 ENABLED
