由于硬件问题、C3 Tx丢弃和帧超时
适用场景
Brocade Fabric OS
问题描述
errdump -a
记录帧超时、指出哪个端口接收到帧(Rx)以及无法在何处 (TX)传输帧、同时记录丢失信号和 超额预订 警报。
2022/02/09-22:31:04, [AN-1014], 2266, SLOT 2 | FID 128, INFO, NFAB1, Frame timeout detected, tx port 9/7 rx port 9/27, sid c8f907, did 678740, timestamp 2022-02-09 22:31:04 .
2023/12/23-10:47:16 (IST), [MAPS-1003], 274485, SLOT 2 | FID 128 | PORT 11/8, WARNING, switch, IB_INFINI_3185_W_N3P6, F-Port 11/8, Condition=ALL_PORTS(PORT_BANDWIDTH/NONE==OVERSUBSCRIBED), Current Value:[PORT_BANDWIDTH, OVERSUBSCRIBED, (TXQL=914 us, TX=72.8%) ], RuleName=defALL_PORTS_OVERSUBSCRIBED, Dashboard Category=Fabric Performance Impact, Quiet Time=15 min.
2023/12/18-01:35:43 (IST), [MAPS-1003], 270764, SLOT 1 | FID 128 | PORT 10/21, WARNING, switch, Nimble2_U_N2S3P1, U-Port 10/21, Condition=ALL_PORTS(LOSS_SIGNAL/min>5), Current Value:[LOSS_SIGNAL, 8 LOS], RuleName=defALL_PORTSLOSS_SIGNAL_5, Dashboard Category=Port Health, Quiet Time=None.
porterrshow
显示链路故障、链路重置、C3丢弃与txt和帧超时相关的错误计数器增量。
/fabos/cliexec/porterrshow:
frames enc crc crc too too bad enc disc link loss loss frjt fbsy c3timeout pcs uncor
tx rx in err g_eof shrt long eof out c3 fail sync sig tx rx err err
391: 45.3g 3.4g 0 0 0 0 0 0 0 43.1k 5 0 5 0 0 43.1k 0 0 2.5k
sfpshow
表示接收功率低
Port 391:
RX Power: -8.1 dBm (155.8uW)
TX Power: -3.0 dBm (500.6 uW)
sfpshow
指示Rx和Tx处于最佳范围 -
portshow
表示远程设备对链路的重置超过发送脱机本机本机的本地端口
portshow 391
Lr_in: 133 Ols_in: 5
Lr_out: 7 Ols_out: 6
