跳转到主内容
Brocade 交换机报告温度过高和 " 过热 "
29
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
适用场景
Brocade (G620)
问题描述
其中一个温度传感器报告值较高
  • 已验证传感器状态
/fabos/cliexec/sensorshow:
sensor  1: (Temperature) is Ok, value is 39 C
sensor  2: (Temperature) is Ok, value is 48 C
sensor  3: (Temperature) is Ok, value is 44 C
sensor  4: (Temperature) is Ok, value is 42 C
sensor  5: (Temperature) is Ok, value is 42 C
sensor  6: (Temperature) is Ok, value is 37 C
sensor  7: (Temperature) is Ok, value is 63 C
sensor  8: (Fan     ) is Ok,speed is 8141 RPM
sensor  9: (Fan     ) is Ok,speed is 8239 RPM
sensor 10: (Power Supply) is Faulty
sensor 11: (Power Supply) is Ok
  • 所有活动传感器(在上述示例中为所有7个传感器)的平均温度值均应为平均值
New to NetApp?
