跳转到主内容
复制脚本时, BES-53248 RCF 配置验证失败
63
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
BES-53248 集群交换机
问题描述
BES 53248 集群交换机在尝试复制 RCF 脚本时报告验证错误:
(Switch)#copy http://172.19.2.1/RCF-Cluster-HA.txt nvram:script RCF-Cluster-HA.scr
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
HTTP Configuration Script transfer starting...
Validating configuration script...
Configuration script validation failed.
Following lines in the script may have problem:
Line 41:: passwords lock-out 0
Line 55:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 59:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 68:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 72:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Total error Lines :: 5
The file being downloaded has potential problems.
Do you want to save this file? (y/n)
New to NetApp?
  • 这篇文章对您有帮助吗?
