跳转到主内容
发出 NTP 警告后自动重新启动 Brocade FC 交换机
127
Visibility:
Votes:
0
Category:
fc-series
Specialty:
brocade
Last Updated:
适用场景
Brocade
问题描述
切换自动重新启动,但许多 NTP 查询失败,导致重新启动
示例:
errdump -a
WARNING,  NTP Query failed: 255.
CHASSIS, CRITICAL, haReboot is automatically triggered for warm recovery from OOM.
CRITICAL, Rebooting the system for recovery - auto-reboot is enabled.
CHASSIS, INFO, First failure data capture (FFDC) event occurred.
CHASSIS, INFO, Processor rebooted - Reset.
New to NetApp?
