Brocade 交换机显示警告:端口上的链路重置
适用于
Brocade 交换机上的端口
问题
- Brocade 交换机将显示
LinkReset on Port
2020/04/08-21:35:56, [C3-1014], 2556, CHASSIS, WARNING, Brocade6510, Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
2020/04/09-09:03:42, [C3-1014], 2557, CHASSIS, WARNING, Brocade6510, Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
- 在命令上、 RX 的 Brocade TX 电源低于 300 UW
sfpshow -all
Port 8:
Identifier: 3 SFP
Connector: 7 LC
Transceiver: 7004404000000000 4,8,16_Gbps M5 sw Short_dist
Encoding: 6 64B66B
Baud Rate: 140 (units 100 megabaud)
Length 9u: 0 (units km)
Length 9u: 0 (units 100 meters)
Length 50u (OM2): 3 (units 10 meters)
Length 50u (OM3): 10 (units 10 meters)
Length 62.5u:0 (units 10 meters)
Length Cu: 0 (units 1 meter)
Vendor Name: BROCADE
Vendor OUI: 00:05:1e
Vendor PN: 57-0000088-01
Vendor Rev: A
Wavelength: 850 (units nm)
Options: 003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max: 0
BR Min: 0
Serial No: HAF6182300004BC
Date Code: 180605
DD Type: 0x68
Enh Options: 0xfa
Status/Ctrl: 0x0
Pwr On Time: 1.24 years (10834 hours)
E-Wrap Control: 0
O-Wrap Control: 0
Alarm flags[0,1] = 0x5, 0x40
Warn Flags[0,1] = 0x5, 0x40
Temperature: 55 Centigrade
Current: 7.506 mAmps
Voltage: 3314.0 mVolts
RX Power: -2.8 dBm (520.8uW)
TX Power: -10.3 dBm (92.4 uW)
