CN1610 意外重新启动后的 SwitchIfIslDownWarn_Alert
适用于
- CN1610 集群互连交换机
- FastPath OS 1.3.0.2
问题
- CN1610 交换机意外重新启动。
Fri Mar 12 05:30:02 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchReboot_Alert , Alerting Resource = CN1610SWITCH-SW1 raised by monitor cluster-switch
Fri Mar 12 05:27:54 CET [node_name-03: vifmgr: vifmgr.clntdev.updated:notice]: Remote device CN1610SWITCH-SW1 (model: CN1610, version: 1.3.0.2, IP address: 192.168.1.1) has been detected on the cluster network.
Fri Mar 12 05:25:58 CET [node_name-04: vifmgr: vifmgr.clntdev.removed:notice]: Remote device CN1610SWITCH-SW1 (model: CN1610) was removed from the cluster network.
- AutoSupport
CLUSTER NETWORK DEGRADED和SwitchIfIslDownWarn_Alert错误。
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW1/ Link Aggregate 1 raised by monitor cluster-switch
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 13 10G - Level raised by monitor cluster-switch
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 14 10G - Level raised by monitor cluster-switch
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 15 10G - Level raised by monitor cluster-switch
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 16 10G - Level raised by monitor cluster-switch
Fri Mar 12 05:31:52 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/ Link Aggregate 1 raised by monitor cluster-switch
Fri Mar 12 05:35:22 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchReboot_Alert , Alerting Resource = CN1610SWITCH-SW1 cleared by monitor cluster-switch
Fri Mar 12 07:14:11 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/ Link Aggregate 1 cleared by monitor cluster-switch
Fri Mar 12 07:14:11 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 13 10G - Level cleared by monitor cluster-switch
Fri Mar 12 07:14:11 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 14 10G - Level cleared by monitor cluster-switch
Fri Mar 12 07:14:11 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 15 10G - Level cleared by monitor cluster-switch
Fri Mar 12 07:14:11 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW2/Slot: 0 Port: 16 10G - Level cleared by monitor cluster-switch
Fri Mar 12 07:16:42 CET [node_name-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchReboot_Alert , Alerting Resource = CN1610SWITCH-SW2 raised by monitor cluster-switch
Fri Mar 12 07:19:33 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = CN1610SWITCH-SW1/ Link Aggregate 1 cleared by monitor cluster-switch
Fri Mar 12 07:22:02 CET [node_name-01: cshmd: hm.alert.cleared:notice]: Alert Id = SwitchReboot_Alert , Alerting Resource = CN1610SWITCH-SW2 cleared by monitor cluster-switch
Fri Mar 12 05:32:10 CET [node_name-03: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: SwitchIfIslDownWarn_Alert[CN1610SWITCH-SW1/ Link Aggregate 1].
