RCF 文件不会使用 tftp 下载到 CN1610
适用场景
- 集群网络交换机 CN1610
- FastPath 1.2.0.7
- 使用 TFTP 传输
问题描述
RCF 文件副本传输会通过 tftp 失败
(CN1610) #copy tftp://user@<tftp_server_ip>//CN1610_RCF_v1.2.txt nvram:script CN1610_RCF_v1.2.scr
Mode........................................... TFTP
Set Server IP.................................. <tftp_server_ip>
Path........................................... ./
Filename....................................... CN1610_RCF_v1.2.txt
Data Type...................................... Config Script
Destination Filename........................... CN1610_RCF_v1.2.scr
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
File transfer failed!
