跳转到主内容
MetroCluster 无法添加用于监控的 Brocade 交换机
47
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
brocade
Last Updated:
适用场景
  • MetroCluster
  • Brocade
问题描述
MetroCluster 无法通过命令添加用于监控的 Brocade 交换机 storage switch add
示例:
::> storage switch add 10.64.xx.xx
Error: command failed: Internal error. Failed to add switch for monitoring on node "node_name" in cluster "cluster_name". Reason: Failed to check if device located at "10.64.xx.xx" is from
supported vendor. For further assistance, contact technical support.
New to NetApp?
