跳转到主内容
Extreme networks VDX8770 switch reports higher fan rpm
14
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
Extreme Networks VDX8770 Switch
Issue
  • Increased temperature in the switch and leading to higher fan rpm which is leading to very noisy environment
  • Event logs shows the blade temperature is going high
2020/01/13-13:38:35:993021, [HIL-5600], 398250/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:38:35:992849
2020/01/13-13:38:53:586722, [HIL-5600], 398252/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:38:53:586514
2020/01/13-13:39:11:182804, [HIL-5600], 398254/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:39:11:182586
  • The fan speed in this example shows at 9000RPM, where as the normal operating range is 5000 to 6000rpm range
NOSCLI show environment fan:
Mon Jan 13 13:16:35 GMT 2020
Rbridge-id: 1
Fan 1 is Ok, speed is 9132 RPM
Fan 2 is Ok, speed is 9174 RPM
Fan 3 is Ok, speed is 9049 RPM
Fan 4 is Ok, speed is 9090 RPM
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
