错误! 在应用时,位于配置脚本文件中的行号 XX 新的 RCF
适用场景
集群交换机Broadcom BES-53248
问题描述
将新RCF文件应用于 Broadcom BES-53248时出错。示例:
(CS1) #script apply BES-53248_RCF_v1.6-Cluster-HA.scr Are you sure you want to apply the configuration script? (y/n) y config ... match cos 5 Unrecognized command : match cos 5 Error! in configuration script file at line number 40. CLI Command :: match cos 5. Aborting script. Execution of configuration script 'BES-53248_RCF_v1.6-Cluster-HA.scr' could not be completed. WARNING: The running configuration may not be the desired configuration. You might want to reload the saved configuration.
