跳转到主内容
EMS报告由于存储端SFP出现故障、在FC端口上检测到链路中断
33
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches<a>2008914376.</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • 小型可插拔(SFP)
  • Cisco交换机
问题描述
  • EMS 日志报告光纤通道目标适配器上的链路轮盖事件:
Thu May 25 01:23:26 AEST [Netapp: fct_tpd_work_thread_0: scsitarget.ispfct.linkBreak:error]: Link break detected on Fibre Channel target adapter 0e. Firmware status code status1 0x2, status2 0x7, and status4 0x0.
Thu May 25 01:30:08 AEST [Netapp: fct_tpd_work_thread_0: scsitarget.hwpfct.linkUp:notice]: Link up on Fibre Channel target adapter 0e.
  • FC目标端口状态在下显示为联机 sysconfig -a
slot 0: Fibre Channel Target Host Adapter 0e
               (QLogic 8324 (8362) rev. 2, <ONLINE>)
               Firmware rev:      8.7.0
               Flash rev:         7.0.3
               Host Port Addr:    ae0700
               FC Nodename:       50:0a:09:80:80:84:xy:xx (500axxxxxxxxxxxx)
               FC Portname:       50:0a:09:81:80:84:yx:yy (500axxxxxxxxxxxx)
               Connection:        PTP, Fabric
               Switch Port:       sw:1/8
              SFP Vendor Name:  AVAGO
              SFP Vendor P/N:   AFBR-57F5MZ-NA3
              SFP Vendor Rev:   01
              SFP Serial No.:   AC1804Jxxxx
              SFP Connector:    LC
              SFP Capabilities: 4, 8, 16 Gbit/S
  • FC目标端口显示 link disconnected 在下 sysconfig -a
slot 0: Fibre Channel Target Host Adapter 0d
         (QLogic 8324 (8362) rev. 2, <LINK DISCONNECTED>)
         Firmware rev:    8.9.0
         Flash rev:      7.0.3
         Host Port Addr:   000000
         FC Portname:     50:0a:09:80:80:84:xy:xx (500axxxxxxxxxxxx)
         Connection:     No link
         Switch Port:     Unknown
       SFP Vendor Name:   FINISAR CORP.
       SFP Vendor P/N:   FTLF8529P4BCVAN1
       SFP Vendor Rev:   A
       SFP Serial No.:   P17BX7G
       SFP Connector:    LC
       SFP Capabilities:  4, 8, 16 Gbit/Sec
  • 根据 fcp-adapter.xml 日志、Rx和Tx功率处于最佳范围。
  • 在连接到受影响端口 的Cisco交换机上、交换机端口Tx电源显示为不适用。
[2023-05-31 17:09:33] Tx Power N/A -- 1.70 dBm -13.00 dBm -1.30 dBm -9.00 dBm
[2023-05-31 17:09:33] Rx Power -2.19 dBm 3.00 dBm -15.90 dBm 0.00 dBm -11.90 dBm
  • 根据  error disabled show int brief 日志,交换机端口处于状态,并且 ITW 在下为交换机端口生成错误 show interface counters
show int brief-
 fc1/8 is down (Error disabled - bit error rate too high)
show interface counters-
[2023-05-31 17:09:32]  System Errorcode  : 0x4042001e MAC Bit error exceeded threshold
[2023-05-31 17:09:32]  Error Type     : Warning
[2023-05-31 17:09:32]  PhyPortLayer    : Fibre Channel
[2023-05-31 17:09:32]  Port(s) Affected  : fc1/8
[2023-05-31 17:09:32]  Error Description : MAC Bit error exceeded threshold [ITW]
  •  我们可以在下看到交换机端口上的端口轻拍条目 show logging log
[2023-05-31 17:09:40]  2023 May 22 09:42:24 sw %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 10%$ Interface fc1/8 is down (Administratively down)  CS1A-naclu01-02_e0e
[2023-05-31 17:09:40]  2023 May 22 09:42:27 sw %PORT-5-IF_UP: %$VSAN 10%$ Interface fc1/8 is up in mode F  CS1A-naclu01-02_e0e
023 May 25 01:29:55 sw %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 10%$ Interface fc1/8 is down (Administratively down) xxxx
[2023-05-31 17:09:40]  2023 May 25 01:30:08 sw %PORT-5-IF_UP: %$VSAN 10%$ Interface fc1/8 is up in mode F  xxxx
  • 可以执行以下步骤进一步隔离问题描述:
  1. 重新拔插 存储和交换机端口上的电缆/SFP。
  2. 执行端到端电缆测试(包括配线板),如果电缆有故障,请更换电缆。
  3. 如果缆线没有故障、请先更换交换机端的SFP、因为Tx电源为NA。
注: 要隔离交换机端口不是问题描述电缆、可将其移至交换机端的未使用/空闲端口、并查看链路是否正常工作。
  1. 如果问题描述仍然存在,则在这种情况下将更换存储端SFP。
New to NetApp?
