跳转到主内容
在切换到无交换机的转换期间发生数据中断
5
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
适用场景
  • FAS8040
  • 将交换集群转换为双节点无交换机集群转换
  • ONTAP 9.7P11
问题描述
  • [1] 在使用缆线将端口 e0a/e0b 直接连接到每个节点之后,操作步骤期间发生了以下文档过渡到双节点无交换机集群数据中断
EMS 日志显示以下内容
[Node-A: vifmgr: vifmgr.lifsuccessfullymoved:notice]: LIF Node-A_clus1 (on virtual server 4294967293), IP address 169.254.49.239, is now hosted on node Node-A, port e0a.
[Node-A: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF Node-A_clus1 (on virtual server 4294967293), IP address 169.254.49.239, is being moved to node Node-A, port e0a.
[Node-A: mgwd: clus.net.switchlessInv:notice]: One or more cluster ports are directly wired to a cluster port on another node, but the "switchless-cluster" option is not enabled.
[Node-A: vifmgr: vifmgr.dbase.checkerror:alert]: VIFMgr experienced an error verifying cluster database consistency. Some LIFs might not be hosted properly as a result.
[Node-A: vifmgr: vifmgr.startup.failover.err:alert]: VIFMgr encountered errors during startup.
  • 然后,数据 LIF 将从托管它们的物理端口中删除
[Node-A: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Data-Vserver1-Lif1 (on virtual server 16), IP address x.x.x.x, is being removed from node Node-A, port e0e
[Node-A: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Data-Vserver1-Lif2 (on virtual server 12), IP address x.x.x.x, is being removed from node Node-A, port e0e.
New to NetApp?
