跳转到主内容
CN1610"show tech-support" 命令显示温度传感器警告
86
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
适用场景
CN1610
问题描述
show environmentshow tech-support 命令部分中的温度传感器警告:
[Mon Feb 01 12:24:40.974 2021] *************** show environment ***************
[Mon Feb 01 12:24:40.974 2021] Temp (C)....................................... 40
[Mon Feb 01 12:24:40.974 2021] Fan Speed, RPM................................. 9300
[Mon Feb 01 12:24:40.974 2021] Fan Duty Level................................. 75%
[Mon Feb 01 12:24:40.974 2021] Temperature traps range: 0 to 60 degrees (Celsius)
[Mon Feb 01 12:24:40.974 2021] Temperature Sensors:
[Mon Feb 01 12:24:40.974 2021] Unit    Sensor  Description     Temp (C)   State       Max_Temp (C)
[Mon Feb 01 12:24:40.974 2021] ----    ------  ----------------  ----------  --------------  --------------
[Mon Feb 01 12:24:40.974 2021] 1     1     CPU & SWITCH    40      Normal      48
[Mon Feb 01 12:24:40.974 2021] 1     2     Left PHY's     40      Normal      42
[Mon Feb 01 12:24:40.974 2021] 1     3     Right PHY's     0       Warning     46
New to NetApp?
