跳转到主内容
Brocade 交换机显示为挂起状态,并出现瞬时 i2c 故障
15
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
状态信息
适用于
Brocade 6520 Fabric OS ( FOS ) 7.4.0 之前的版本
运行 7.3.1a 之前的 FOS 版本的其他 Brocade 型号
问题
Brocade 交换机上的一个或多个端口或组件可能会永久脱机。  此外,在某些情况下,交换机可能会对 SSH 或 Web 命令不响应。
I2C 访问故障导致各种症状,例如:
  1. slotshow 命令输出可能会将某些组件标记为带有,"*"表示对该组件没有 I2C 访问权限。
  2. switchshow 命令输出可能表示 " Speed Mismatch / Incompatible SFP
  3. tempshow 命令输出可能会显示 "" unknown"
  4. 控制台日志(dmesg)可能包括:
pcf954x_select_mux: Failed to select the I2Cmux (addr=76, val=08, err=-1 id=0)!
•在 RAS 日志中,查找以下错误。
 [HIL-5010], 17389714/0, CHASSIS, WARNING, Brocade6520, Warning, license id access problems (-4)!!, hil_sb_wwn_conf, line:   232, comp:secd,
 [LIC-5015], 17389715/0, CHASSIS, ERROR, Brocade6520, Failed to get WWN from HIL. Return code -4 . , id.c, line: 80,    comp:secd,
 [LIC-5002], 17389716/0, CHASSIS, ERROR, Brocade6520, Error reading license records. , db.c, line: 314, comp:secd,
 [EM-5010], 17389717/0, CHASSIS, WARNING, Brocade6520, wwn card slot_out ignored for onboard fru seeprom, OID:0x46100000,   power.c, line: 3414, comp:emd,
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
