跳转到主内容
如何确定Brocade交换机的电源(PS/PSU)或风扇的NetApp部件号
536
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
适用场景
  • SAN
  • MetroCluster交换机
  • Brocade交换机 G720、G620、G630、6520、6510、6505、5100、X6-4和X6-8
  • Brocade主干DCX8510
描述
Brocade 6520、6510、6505或5100交换机上报告电源或风扇出现故障:
Brocade DCX8510主干网报告电源出现故障
  • 报告故障PS:
psshow :
Power Supply #1 is OK
Airflow Direction : Port side Exhaust (Reverse)
Power Supply #2 is faulty*
* = No system control access to power supply.
  • 报告故障风扇:
fanshow        :
Fan 1 is Ok, speed is 4071 RPM
Fan 2 is faulty
Fan 3 is Ok, speed is 4119 RPM
Fan 4 is Ok, speed is 18977 RPM
Fan 5 is Unknown
  • Brocade X6-4和Brocade X6-8上报告电源或风扇出现故障:
psshow        :
V10N18,   DUCXXXXXXHJ      ,23-0000161-01,A0,DELTA,ECXXXXXXX42     ,00,DUXXXX8N
V10N22,   DUCXXXXXX1H      ,23-0000161-01,A0,DELTA,ECXXXXXXX42     ,00,DUXXXX2N
fanshow        :
Fan 1 is Ok, speed is 4067 RPM
Fan 2 is faulty
Fan 3 is Ok, speed is 4067 RPM
  • Brocade X6-4导向器:两个风扇组件,非端口侧排气或进气,用于1+1冗余。每个组件包含2个风扇、共4个。系统需要4个正常运行的风扇中的3个风扇才能运行。一个风扇部件可以热插拔、但必须立即更换。
  • Brocade X6-8导向器:三个风扇组件,非端口侧排气或进气,用于2+1冗余。每个组件包含2个风扇、共6个。系统需要6个正常运行的风扇中的5个风扇才能运行。一个风扇部件可以热插拔、但必须立即更换。
  • Brocade 6505:交换机还提供了一个用于单个热插拔PS设备的选项。该电源发生故障将导致开关失效,并且不会显示任何 LED 灯。
  • Brocade DCX8510主干网
    • 电源故障
xxxxx20 Power Supply #1 is faulty Brocade DCX8510-8  WWN Serial Num: AFXxxxxL00K     Power Supply #1 is faulty
POWER SUPPLY  Unit: 1
Header Version:         2
Power Consume Factor:   0
Factory Part Num:       23-0000067-02
Factory Serial Num:     AGCxxxxLB8Z
New to NetApp?
