跳转到主内容
Brocade 交换机处于挂起状态、出现瞬态 I2C 故障
11
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
状态信息
适用于
Brocade 6520
在 v7.3.1a 或 v7.4.0 之前
问题
I2C 访问故障导致各种症状,例如:
  1. slotshow 命令输出可能会将某些组件标记为带有,"*"表示对该组件没有 I2C 访问权限。
  2. switchshow 命令输出可能表示 " Speed Mismatch / Incompatible SFP
  3. tempshow 命令输出可能会显示 "" unknown"
  4. 控制台日志(dmesg)可能包括:
pcf954x_select_mux: Failed to select the I2Cmux (addr=76, val=08, err=-1 id=0)!
•在 RAS 日志中,查找以下错误。
 [HIL-5010], 17389714/0, CHASSIS, WARNING, Brocade6520, Warning, license id access problems (-4)!!, hil_sb_wwn_conf, line:   232, comp:secd,
 [LIC-5015], 17389715/0, CHASSIS, ERROR, Brocade6520, Failed to get WWN from HIL. Return code -4 . , id.c, line: 80,    comp:secd,
 [LIC-5002], 17389716/0, CHASSIS, ERROR, Brocade6520, Error reading license records. , db.c, line: 314, comp:secd,
 [EM-5010], 17389717/0, CHASSIS, WARNING, Brocade6520, wwn card slot_out ignored for onboard fru seeprom, OID:0x46100000,   power.c, line: 3414, comp:emd,
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
