跳转到主内容
Brocade交换机上报告了机箱警告C4-1006和严重C4-1010消息
297
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
状态信息
适用场景
  • Brocade DCX
  • X6董事
问题描述格式
  • 交换机上的一个端口刀片进入禁用状态,并在errdump下报告以下错误:
2020/01/22-19:07:06, [C4-1010], 433, SLOT 2 | CHASSIS, CRITICAL, DCX, S12,C0: Above normal hardware errors were observed: fault1:0x1, fault2:0x64 thresh2:0xb000xxx.
2020/01/22-19:20:41, [C4-1006], 434, SLOT 2 | CHASSIS, WARNING, DCX, S12,C0: Various non-critical hardware errors were observed: fault1:0xa, fault2:0x64 thresh1:0xa0000xxx.
2024/04/10-23:18:47:025732 (IST), [C4-1045], 2241569/1871933, SLOT 1 | CHASSIS, INFO, DCX, Single parity error detected in ftb statistics memory, slot 4 index 0, OID:0x43xxx, SPOID:0x43xxx, c4_ftb.c, line: 591, comp:insmod, ltime:2024/04/10-23:18:47:0254xx
  • 在上面的示例中、插槽2 CP报告了此错误、它正在监控交换机、但报告插槽12 (S12)芯片0上的刀片式服务器上存在问题描述。
  • HAshow 将当前活动CP报告为插槽2:
Local CP (Slot 2, CP1): Active, Warm Recovered
Remote CP (Slot 1, CP0): Standby, Healthy
HA enabled, Heartbeat Up, HA State synchronized
  • slotshow -m 显示受影响插槽(此处的插槽12根据上述日志段)上的刀片式服务器运行状况良好。
slotshow -m:
Slot   Blade Type     ID    Model Name     Status
  1     CP BLADE    175     CPX6           ENABLED
  2     CP BLADE    175     CPX6           ENABLED
  3     SW BLADE    178     FC32-48        ENABLED
  4     SW BLADE    178     FC32-48        ENABLED
  5     SW BLADE    178     FC32-48        ENABLED
  6     SW BLADE    178     FC32-48        ENABLED
  7     CORE BLADE  177     CR32-8         ENABLED
  8     CORE BLADE  177     CR32-8         ENABLED
  9     SW BLADE    178     FC32-48        ENABLED
 10     SW BLADE    178     FC32-48        ENABLED
 11     SW BLADE    178     FC32-48        ENABLED
 12     SW BLADE    178     FC32-48        ENABLED
  • 在继续解决方案之前、请先检查是否仍生成错误消息。
  • 如果错误消息被停止,则可以忽略它们, C4-1045是一种信息类型的消息(严重性-信息),流监控器可能会错误地显示该消息,它通常是瞬时的,如果消息不再出现,则可以忽略它。
New to NetApp?
