跳转到主内容
系统无法启动、并显示“ System DIMM Configuration is not supported (不支持系统 DIMM 配置)”
152
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
状态信息
适用场景
  • FAS8200
  • FAS8020
  • FAS2620
  • AFF8080
  • DIMM
问题描述
存储系统无法启动并自行停止。存储系统启动时报告以下错误消息:
示例:
System DIMM configuration is not supported on FAS8200
Please check the DIMM placement on SLOT-1 SLOT-2 ...
Halting...
示例:
DIMM missing in slot DIMM-2
DIMM missing in slot DIMM-3
System DIMM configuration is not supported by FAS8020
示例:
System DIMM configuration is not supported on FAS2620
Please check the DIMM placement on SLOT-1 ...
Halting...
New to NetApp?
