跳转到主内容
由于凭据无效,在 EMS 中看到 secd.ldap.noServers
329
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
适用于
  • ONTAP 9
  • 无效的 LDAP 配置
问题
  • EMS:
Thu Aug 12 01:10:56 -0500 [Node1: secd: secd.conn.auth.failure:notice]: Vserver (SVM) could not authenticate over the network to server (LDAP1). Error: Invalid credentials (Service: LDAP (NIS & Name Mapping), Operation: Check LDAP Config).
Thu Aug 12 01:10:57 -0500 [Node1:: secd: secd.ldap.noServers:EMERGENCY]: None of the LDAP servers configured for Vserver (SVM) are currently accessible via the network for LDAP service type (Service: LDAP (NIS & Name Mapping), Operation: Check LDAP Config).
  • SEC D 日志片段:
0000002b.00ea6324 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854] Failure Summary:
0000002b.00ea6325 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854] Error: Validate the Ldap configuration procedure failed
0000002b.00ea6326 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854]   [  0 ms] Hostname found in Name Service Cache
0000002b.00ea6327 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854]   [    0] Resolved LDAP servers: 10.13.xx.xx. Vserver: -1
0000002b.00ea6328 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854]   [    0] Failed to initiate Kerberos authentication. Trying NTLM.
0000002b.00ea6329 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854]   [   298] Unable to connect to LDAP (NIS & Name Mapping) service on ldap.xxx.xxxx.org (Error: Invalid credentials)
0000002b.00ea632a 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854]   [   299] No servers available for LDAP_NIS_AND_NAME_MAPPING, vserver: -1, domain: .
0000002b.00ea632b 046a6848 Wed Oct 11 2023 00:14:57  05:30 [kern_secd:info:10854] **[   299] FAILURE: Unable to make a connection (LDAP (NIS & Name Mapping):), Result: RESULT_ERROR_SECD_NO_SERVER_AVAILABLE
New to NetApp?
