A300/FAS8200、A200/FAS2600、A220/FAS2700、C190上的e0a/e0b链路盖可能会发生发生原因A接管
适用场景
- AFF A300、FAS8200.
- AFF A200、FAS2650、FAS2620
- AFF A220、AFF C190、FAS2750、FAS2720
- ONTAP 9
问题描述
- 集群端口e0a或e0b (或这两个端口)同时发生链路翻盖或关闭。
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
- 检查集群端口状态和存储故障转移状态:
cluster1::>network port show -ipspace Cluster
Node: cluster1-01
Speed(Mbps) Health
Port IPspace Broadcast Domain Link MTU Admin/Oper Status
e0a Cluster Cluster down 9000 1000/- -
e0b Cluster Cluster down 9000 1000/- -
Node: cluster1-02
Speed(Mbps) Health
4 entries were displayed.
cluster1::>storage failover show
Takeover
Node Partner Possible State Description
cluster1-01 cluster1-02 false Connected to cluster-02, Partial
giveback, Takeover is not possible:
The version of software running on
each node of the SFO pair is
incompatible, NVRAM log not synchronized
cluster1-02 cluster1-01 - Waiting for cluster applications to
come online on the local node
Offline applications: mgmt, vldb,
vifmgr, bcomd, crs.
如果端口未恢复正常、并且启用了连接、流明度和可用性监控(vl和平 等)
- 其中一个节点将发生"仲裁不足"崩溃。
PANIC : Received PANIC packet from partner, receiving message is (Coredump and takeover initiated because Connectivity, Liveliness and Availability Monitor (CLAM) has determined this node is out of quorum.
- 发生故障的节点将被接管、正常运行的节点将提供所有数据。
如果端口未恢复正常、并且未启用连接、流明度和可用性监控(vl和平 等)
- 不会发生存储接管、并且两个节点都将丢失仲裁。 两个节点均不提供数据。
- 请参见:SU436:[Impact:critical]已更改管理接管默认配置
- 在EMS日志中可以找到类似消息:
Jun 08 12:30:09 [xxx-02:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0b on node naptp06c-02 has gone down unexpectedly.
Jun 08 12:30:10 [xxxc-02:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node naptp06c-02 has gone down unexpectedly.
Jun 08 12:31:00 [xxx-02:monitor.globalStatus.critical:EMERGENCY]: Controller failover of xxx-01 is not possible: partner mailbox disks not accessible or invalid. One or more mirrored aggregates are degraded.
Jun 08 12:31:02 [xxx:callhome.clam.node.ooq:EMERGENCY]: Call home for NODE(S) OUT OF CLUSTER QUORUM.
