A300/FAS8200 , A200/FAS2600 , A220/FAS2700 , C190 上的 e0a/e0b 链路板可能导致接管
状态信息
适用场景
- AFF A300/FAS8200
- AFF A200 , FAS2650 , FAS2620
- AFF A220 , AFF C190 , FAS2750 , FAS2720
- ONTAP 9
问题描述
- 集群端口 e0a 或 e0b (或两个端口)会同时出现链路挡板或关闭。
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down. Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable. Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down. Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable. Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down. Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable. Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down. Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
- 检查集群端口状态和存储故障转移状态:
cluster::> network port show -role cluster (network port show) Node: node1 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster down 9000 1000/- - e0b Cluster Cluster down 9000 1000/- - Node: node2 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster down 9000 1000/- - e0b Cluster Cluster down 9000 1000/- - 4 entries were displayed.
cluster::storage failover> storage failover show
Takeover
Node Partner Possible State Description
cluster-01 cluster-02 false Connected to cluster-02, Partial
giveback, Takeover is not possible:
The version of software running on
each node of the SFO pair is
incompatible, NVRAM log not synchronized
cluster-02 cluster-01 - Waiting for cluster applications to
come online on the local node
Offline applications: mgmt, vldb,
vifmgr, bcomd, crs.
如果端口没有备份、并且启用了连接、则激活和可用性监视器( CLAM )
- 其中一个节点上将出现“超出法定人数”紧急情况。
PANIC : Received PANIC packet from partner, receiving message is (Coredump and takeover initiated because Connectivity, Liveliness and Availability Monitor (CLAM) has determined this node is out of quorum.
- 将接管出现紧急情况的节点、正常运行的节点将为所有数据提供服务。
如果端口没有备份、并且连接不启用活动和可用性监视器( CLAM )
- 不会发生存储接管,并且两个节点都将超出仲裁。 两个节点都不会提供数据。
- 请参见: SU436 : "Impact : critical" (影响:严重)状态下的命令执行接管默认配置已更改
- 在EMS日志中可以找到类似的消息:
Jun 08 12:30:09 [xxx-02:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0b on node naptp06c-02 has gone down unexpectedly.
Jun 08 12:30:10 [xxxc-02:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node naptp06c-02 has gone down unexpectedly.
Jun 08 12:31:00 [xxx-02:monitor.globalStatus.critical:EMERGENCY]: Controller failover of xxx-01 is not possible: partner mailbox disks not accessible or invalid. One or more mirrored aggregates are degraded.
Jun 08 12:31:02 [xxx:callhome.clam.node.ooq:EMERGENCY]: Call home for NODE(S) OUT OF CLUSTER QUORUM.
