跳转到主内容
ONTAP 9 支持的最小聚合大小是多少?
33
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9.x
  • 聚合
问题解答
  • ONTAP 9 至少支持使用 Raid4 的 2 个磁盘
  • 操作步骤
    cluster::*> set advanced
    cluster::*> aggr create -aggregate SmallAggr -diskcount 2 -raidtype Raid4 -force-small-aggregate true
    Warning: You are creating an aggregate with fewer disks than recommended.
    Do you want to continue? {y|n}: y
    Info: The layout for aggregate "SmallAggr" on node "cluster-01" would be:
        First Plex
         RAID Group rg0, 2 disks (block checksum, raid4)
                                  Usable Physical
          Position   Disk            Type       Size    Size
          parity    VMw-1.7           SSD         -     -
          data     VMw-1.8           SSD      28.42GB  28.44GB
        Aggregate capacity available for volume use would be 25.58GB.
    [Job 107] Job succeeded: DONE
追加信息
不适用
