跳转到主内容
由于 X306_WMANT02TSSM 驱动器上出现介质错误, WAFL 不一致
2
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • 驱动器 X306_WMANT02TSSM 正在运行固件 NA09
  • WAFL 用户数据不一致
问题描述
  • 多个磁盘出现未恢复的介质错误
Sat Dec 04 00:45:45 +0100 [node-1: disk_server_0: disk.ioMediumError:notice]: Medium error on disk 0d.26.11: op 0x28:6c87fed9:0240 sector 1820852325 SCSI:medium error - Unrecovered read error - If the disk is in a RAID group, the subsystem will attempt to reconstruct unreadable data (3 11 0 0) (7090) Disk 0d.26.11 Shelf 26 Bay 11 [NETAPP   X306_WMANT02TSSM NA09] S/N [WD-WMAUR0521188] UID [500605BA:00106614:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000]
  • RAID 在重建条带时出现问题(从更换的和重建的磁盘触发)
Sat Dec 04 13:43:36 +0100 [node-1: raidio_thread: raid_multierr_bad_block_1:error]: params: {'disk_rpm': '7200', 'vendor': 'NETAPP  ', 'firmware_revision': 'NA00', 'shelf': '26', 'disk_info': 'Disk /aggr_cns_n06_sata_00/plex0/rg1/0d.26.6 Shelf 26 Bay 6 [NETAPP   X306_SMBPE02TSSM NA00] S/N [ZC23P4EB] UID [500605BA:0152D794:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000]', 'volumeBno': '7996573056', 'site': 'Local', 'bay': '6', 'carrier': '', 'serialno': 'ZC23P4EB', 'owner': '', 'model': 'X306_SMBPE02TSSM', 'disk_type': '6', 'blockNum': '183961984'}
  • 报告了 WAFL 不一致错误
Sat Dec 04 13:47:40 +0100 [node-1: wafl_exempt11: wafl.raid.incons.userdata:error]: WAFL inconsistent: inconsistent user data block at VBN 8430607296 (vvbn:1345580529 fbn:105274 level:0) in public inode (fileid:23150065 snapid:0 file_type:1 disk_flags:0x2 error:120 raid_set:1) in volume vol1@vserver:78133db2-bc33-11e4-8678-1234567890.
Sat Dec 04 13:47:40 +0100 [node-1: wafl_exempt11: wafl.incons.userdata.vol:alert]: WAFL inconsistent: volume vol1@vserver:78133db2-bc33-11e4-8678-1234567890 has an inconsistent user data block. Note: Any new Snapshot copies might contain this inconsistency.
  • 系统中的驱动器运行寿命超过 6 年
New to NetApp?
